Desktop
Geändert 24.11.2010
Ice Machine
GA-MA770-UD3
GA-MA770-UD3
| Hersteller | AMD |
| Codename | Deneb |
| Revision | RB-C2 |
| Technologie | 45 nm |
| Taktrate | 3200 |
| Multiplikator | 16.00 |
| Frontside Bus | 800 |
| L1 Cache | 512 |
| L2 Cache | 2048 |
| Northbridge | ATI 770 Revision 00 |
| Southbridge | AMD SB700 Revision 00 |
| BIOS | FJ |
| Interne Anschlüsse | 3 PCI |
| Größe | 2048 |
| Typ | DDR2 (PC2-6400) |
| Timing | 5-5-5-15-23 at 400.0 MHz, at 1.8 volts (CL-RCD-RP-RAS-RC) |
| Takt | 400 |
| Größe | 2048 |
| Takt | 400 |
| Chipset | GeForce GTX 260 |
| RAM | 896 |
| Treiber | 8.17.12.6099 |
| Typ | Festplatte (intern) |
| Details | Cache: 16384 KB |
| Kapazität | 500 |
| Interface | Serial ATA |
| Temperatur | 22.00 |
| Kapazität | 300 |
| Interface | Parallel ATA |
| Temperatur | 28.00 |
| Größe | 22.0" (47 cm x 30 cm) |
| Auflösung | 1680 x 1050 @ 59Hz |
| Provider | 1&1 |
| Downstream | 3456 |
| Upstream | 448 |
| CPU | 7.3 |
| RAM | 7.3 |
| Grafik | 7.1 |
| Grafik Spiele | 7.1 |
| HDD | 5.9 |
