Desktop
Geändert 18.10.2010
Ice
P5QL PRO
P5QL PRO
| Hersteller | Intel |
| Codename | Kentsfield |
| Revision | G0 |
| Technologie | 65 nm |
| Taktrate | 2400 |
| Frontside Bus | 1064 |
| L1 Cache | 256 |
| L2 Cache | 8192 |
| Northbridge | Intel P45/P43 Revision A3 |
| Southbridge | Intel 82801JR (ICH10R) Revision A3 |
| BIOS | 0601 |
| Interne Anschlüsse | 6 PCI |
| Größe | 2048 |
| Typ | DDR2 (PC2-6400) |
| Timing | 5-6-6-18-24 at 400.0 MHz, at 1.8 volts (CL-RCD-RP-RAS-RC) |
| Takt | 400 |
| Größe | 2048 |
| Takt | 400 |
| Chipset | GeForce 9800 GTX/9800 GTX+ |
| RAM | 512 |
| Treiber | 6.14.11.8048 |
| Typ | Festplatte (intern) |
| Details | Cache: 16384 KB |
| Kapazität | 500 |
| Interface | Serial ATA |
| Temperatur | 23.00 |
| Größe | 21.7" (48 cm x 27 cm) |
| Auflösung | 1680 x 1050 @ 60Hz |
