Notebook
Geändert 25.10.2010
zanders-Kleiner
SATELLITE PRO T130
SATELLITE PRO T130
| Codename | Penryn |
| Revision | R0 |
| Technologie | 45 nm |
| Taktrate | 1297 |
| Frontside Bus | 797 |
| L1 Cache | 128 |
| L2 Cache | 3072 |
| Northbridge | Intel GS45 Revision 07 |
| Southbridge | Intel 82801IM (ICH9-M) Revision 07 |
| BIOS | V2.00 |
| Interne Anschlüsse | 1 PCI |
| Größe | 2048 |
| Typ | DDR3 (PC3-8500F) |
| Timing | 7-7-7-20-27 at 533.3 MHz, at 1.5 volts (CL-RCD-RP-RAS-RC) |
| Takt | 533 |
| Größe | 2048 |
| Takt | 533 |
| Chipset | Mobile Intel(R) 4 Series Express Chipset Family |
| RAM | 1838 |
| Treiber | 8.15.10.1883 |
| Typ | Festplatte (intern) |
| Details | Cache: 8192 KB |
| Kapazität | 320 |
| Interface | Serial ATA |
| Temperatur | 27.00 |
| Größe | 13.2" (29 cm x 17 cm) |
| Auflösung | 1366 x 768 @ 60Hz |
